8th Wall Errors
2 posts · 31 views
Telmo Telmo dos Reis #1
I understand that the original Depthkit templates in 8thwall are deprecated. I am now trying to use the suggested Evercoast template but I keep getting this error when building:
”Access for dependency with alias [depthkit-mesh-sequence-player] does not permit current action”
Is there a way to get around this?
Hi, Telmo - It looks like there’s an issue relating to how 8th Wall clones the module. I have submitted a ticket to 8th Wall to address this, but in the meantime, you should be able to get around this by removing and reimporting the module in your project:
  1. In the Modules section, remove the depthkit-mesh-sequence-player module (right-click, then click “remove”).
  2. Re-add it by clicking the “+” button and searching for depthkit-mesh-sequence-player or importing it from the module’s webpage
  3. The project should now build successfully
I have updated the each template project’s descriptions and readme to reflect this known issue, and will update you once it’s resolved.
