@Terence You can now build your own web player to render Depthkit captures exported in streaming textured geometry format using our newly updated Depthkit.js repository! Follow the instructions in the README to set this up on your own local or cloud-hosted server. This is immediately available to use for anyone with the Depthkit v0.8.1 beta, and will be the primary way to get Depthkit captures to render on the web going forward. Our new 8th Wall templates are built on top of this module, and will continue to be more user-friendly way to get Depthkit captures to play in WebXR. The beta documentation will be updated shortly to reflect these changes.
(The previous Depthkit Core-only version of Depthkit.js which rendered Combined per Pixel video exports has been moved to a deprecated repository.)
Depthkit captures which use our 8th Wall template for playback are viewable in Quest by loading the 8th Wall URL in the headset’s browser.
If instead you would like to build a native Android app to run directly on the Quest locally, our recommendation is:
- Export your capture as a Combined Per Pixel video with the Meta Quest preset applied - This is different than the Draco-based streaming geometry sequence format used in our web player and 8th Wall.
- Create a Unity 2020.3 project following Meta’s guide on configuring your project for Quest.
- Add the Combined per Pixel video, poster, and metadata to the project’s Assets bin.
- Follow our Depthkit Studio Lite renderer documentation to set up your capture to playback performantly on Quest hardware.
- Build directly from Unity to the headset, or build the APK and then sideload it onto the headset.
Our upcoming releases of Depthkit 0.8.1 and Depthkit Expansion Packages for Unity (Phase 10) will come with updates to our documentation to make this all more clear.
