Hi there,
I’d like to process an older Depthkit capture (an obj sequence and associated video file) in a new DepthKit project.
Is it possible to import capture folders from other projects into newer projects?
Lets say I moved the older ’TAKE_xx_xx_xx_xx_xx” into the newer project folder. Is there a way to link the older folder to the newer DepthKit project?
Or is this intentionally not possible - because newer captures might not be backward compatible?
In which case, what is the “Open Project Folder’ button in the Recordings Library tab intended for? I had imagined that was it’s function, but clicking on it just drills down to the file level. it seems to be looking for a file not a folder.
Thank you!
