Hello! I’m using the refinement workflow and Depthkit Cinema for my videos. Because our target device is mobile VR, we need to lower the resolution of the videos. Rather than doing this inside Unity, I would like to export custom sizes from After Effects. The question now is, how do I need to change the .txt files so that they properly recognize my new resolution? Is it enough to just change “TextureHeight” and “TextureWidth” or are there other important parameters?
How to work with custom size Depthkit videos from After Effects to Unity
3 posts · 482 views
Hi @JonasChristen! You actually don’t need to edit the metadata text file at all, even if you change the video file resolution for Unity.
Hi Jillian,
So the .txt files are only for depth information then, good to know.
Thanks for your reply!
