I’m trying to push the cinema/depth pairing workflow to get the best results.
I’d be happy to have some feedback on my current approach to make sure I’m on the right path. I also have a few questions related.
My setup is composed of a 8k (UHD2) cinema camera rig paired with a kinect azure. Both cinema and deph lenses are rigged as close as possible and parallel to each other. The lens used is a Laowa 12mm zero-d (low distorsion). Both FOV are really similar for the depth resolution I’m aiming (640x576).
In my first pairing tests I managed to get an overall pairing accuracy of 66%, saying that I was still having a spatial offset between the Cinema RGB and the depth data once linked and synced. (The temporal sync is frame accurate and verified). I noticed that the lens I use for the cinema camera has significant breathing when moving the focus, I’m assuming that would impact the pairing worfklow. Additionally, I was probably aiming at doing too much coverage/sample.
I did another round of pairing test with a way better result:
Lens Accuracy 87.45%
Lens coverage 69.94%
Sampled volume 4.74 m3
Pairing accuracy 80-70% depending on the ratio of coverage vs precision.
Here is the method I used :
I determined a zone/volume in my setup that will be the area of the subject.
Unfortunately this 12mm lens has “breathing” when we adjust the focus. So I framed my subject/zone in order to determine the depth/cinema position and lock the focus and aperture to cover it properly.
Once I had that aperture/focus lock, I did the adobe lens profiling operation. The idea was to keep is exact same lens/camera parameter from profiling to pairing. Out of the box the lens have low distortion and the profile seems to be good when I check it in photoshop on test frames.
For the pairing process I started with the chart at 3ft from the cameras, then at the front, middle and slighty back of the established zone for the subject. For each of those z positions I captured samples by panning/tilting the camera rig in order to get minimum 9 samples covering the different zones of the third ratio.
This process gives me good result for a determined volume/zone of work, focus position and aperture.
I assume that any changes of the aperture and focus will have an impact.
Questions :
- When capturing sample of the pairing chart, the pink dots are “dancing”, they are not staying fixed as it seems to be in the tutorial video. Anything wrong here ? (depthkit v0.6.2 - E__2023-03-17-io8k_dual_pov_v2 2023-03-17 11-58-18.mp4 - Google Drive)
- Can you confirm that the breathing of a lens have direct impact on the lens creation profile as well as the pairing process ?
- Is there anything I should adjust in my current process ?
- What is a reasonable target for high level pairing accuracy ? is 90% realistic ? 🙂
Thanks,
Martin - FnP studios.
