Hi, @FedericoGuardabrazo - Sorry to hear you’re having issues with the sensor connection.
The screenshot in our documentation was the most recent version at the time the guide was published, and we haven’t run into any issues with the drivers Microsoft has released since then. I will clarify this in the documentation.
Can you provide some more information about the computer you are using and the troubleshooting steps you have already tried?
- What is the behavior you are seeing that indicates there is an issue? Are the sensors not appearing in Depthkit? Are they not appearing in Windows Device Manager? Are they listed but fail to stream?
- Which version of Windows are you running? (As reported in “About Windows”, e.g. “Windows 10 Version 21H2 Build 19044.2965”)
- Do other USB devices work when plugged into the StarTech card’s USB ports?
- Are the sensors successfully streaming in Depthkit (and/or the Azure Kinect Viewer utility found in the Azure Kinect SDK) when plugged into other USB ports on the computer, but failing to do so when they are plugged into the USB ports found on the StarTech card?
- What is the status of the indicator lights on the front and back of each sensor when it is plugged into the StarTech card?
- Are you plugging the sensors directly into the StarTech card’s USB ports using the 3’ USB Type-C to Type-A cable provided with the sensor, or are you using extenders or alternate cables? If using other cables, have you tried bypassing them to see if they are introducing any issues?
Let us know the answers to the above, and we’ll go from there. Thanks!
