[UI] It would be easier to use with the input the parameter numbers but using slider bar only
3 posts · 190 views
PhilipHan Philip Han #1
Hi Depthkit.
A little suggestion: It is hard for user to set the parameter to the number we needed only with sliders.
For example the live output texture width and height. It would be a good idea to add parameter number input in the UI.
螢幕擷取畫面 2022-11-08 193148
Hi, @PhilipHan . Thanks for the feedback. We recognize that direct entry of precise values into Depthkit’s parameters is important for many users, and we are incorporating this feature into a future version of Depthkit.
Update: As of Depthkit v0.6.1, you can now directly type in the maximum livestream resolution values!
